View Full Version : Fiery X3e System Software CD
Pages : [1] 2
copy shop
12-30-2007, 10:12 PM
I have tried to call and emailed Konica Minolta for help but this is their answer:
Hi, system code for the Fiery's is only available from Konica Minolta authorized and trained technicians. Please contact your service rep for assistance in this matter, thank you and happy holidays
Fiery X3e System Software CD - The 2 files for the Dos setup
I want to install a new hard drives into 3 Minolta Pi6000Pro Servers.
These servers also only work with the Di-650, by the way
If AnyOne has the original X3e CD, I would be willing to purchase it.
I have the setup instructions if anyone needs it.
Thanks Tammy
pepper38_cnd
12-31-2007, 07:46 PM
Are you sure its not the system code for the pi6500 Pro you are looking for? If so let me know.
copy shop
12-31-2007, 07:54 PM
Maybe I do NEED the code if that is what they are calling it
BUT
The instalation for new drives refers to The 2 files for the Dos setup is
filename1 the smaller file from the Fiery X3e System Software CD AND
filename2 the larger file from the SAME Fiery X3e System Software CD
P.S. I 'll take the code if that's what I need
Tammy
pepper38_cnd
12-31-2007, 08:05 PM
I do not see a pi6000pro only a pi6500pro listed for the Di650, there is a ISO file (the original operating system) and many patches. If you can confirm that you have a Pi6500 pro I can see about downloading the files and getting them to you.
copy shop
12-31-2007, 08:11 PM
Pi6500 pro
Mandalke@charter.net
I am on high speed
Thanks so much
pepper38_cnd
01-01-2008, 03:08 PM
Glad to see things went the way they were supposed to with the Torrent File, Check your email for a YouSendIt link to download all the patches .
Good Luck
copy shop
01-01-2008, 03:17 PM
Again - The 2 files were exactly what was needed!
I already did the 3 servers and will worry about the printing part later, I have already set that up before, so that's not really a job.
OK....I'll be looking out for the patch files
Thanks again
Tammy
pepper38_cnd
01-01-2008, 03:32 PM
WOW you did 3 servers on NEW YEARS DAY!
Tell your boss you deserve a raise.
copy shop
01-24-2008, 05:49 AM
Do you know where I can download a service manual and suppoert solutions code infor for a Konica Color Force 8050.
I DID have another problem eailer tonight with the setting of the toner adding unit, but I got that figured out.
P.S. The 3 Minolta 6500 pro server I did on New years; YES That was an all nighter, but they All work great ! Thanks to your help.
Thanks again Tammy
pepper38_cnd
01-24-2008, 11:57 AM
It's in the mail.
baret
03-10-2008, 09:39 AM
Hi,
I need to Fiery X3e System Software CD for a Minolta CF 9001.
Hellp me.
copy shop
03-14-2008, 08:13 PM
I don't personally have any of those model machines in my shop
Sorry
You can try this person pepper38_cnd
in the members section of this site area of Konica Minolta
mitchl
03-14-2008, 08:51 PM
You mean to tell me that there is still a running 9001 some where in the world, now thats hard to believe!:eek:
I found version 2.0 on the site but its a huge file(146.7 megs) that would have to be burned and shipped, which I dont mind doing but not on my Fed-X account. Soooooo if you want to set up a will-call shipping deal for this let me know and I'll burn the system software disk for ya!
copy shop
03-14-2008, 09:05 PM
I do not know anything about the CF 9001 .
I only deal with Toshiba 55/65/80 and now Konica 7165 and Di-650's.
I did do a couple of the Konica 8050 color machines
and cf 2002 and a Konic a 8031.
I have gotten my information from pepper38_cnd
pepper38_cnd
03-15-2008, 03:57 AM
PM me I'll give you a link.
pepper38_cnd
03-15-2008, 05:00 PM
Were you able to download the file or do we need to try another method?
baret
03-15-2008, 09:11 PM
I can't succeed. Displaying this message :" An error occurred opening that folder of the FTP Server.Make sure you have permission to access that folder."
pepper38_cnd
03-15-2008, 09:47 PM
If you use Yahoo or MSN messenger... message me now and i will transfer the file... pepper38_cnd for either
RockETop
03-15-2008, 10:44 PM
I hope you have a parallel port.....
baret
03-20-2008, 04:25 PM
I have a PC with Windows 98 and parallel port
doctech
04-07-2008, 06:20 PM
I am in the same boat with a Minolta CF1501 color copier. I need the system software to redo the hard drive. Where do you get it?
Sbarro
06-17-2008, 10:37 PM
Hallo. We have a Di551 with X3e and some manuals with Pi6500 state.
System software on the fiery is in german language and i need to change this.
Besides i can't enter the setup for fiery (password).
I believe it's the same version ?. Can you help me ?
copy shop
06-18-2008, 12:55 AM
First off I have read at the monolta site that the 6500 Pro controller can only be attached the the DI-650 and that is the only model I have actually put the 6500pro onto myself....I beleve the e-6500 series is used for the DI-551 ....with that in mind
You say your System software on the fiery is in german language?
It will depend on who and where is was installed, but/and also if your using the 6500PRO-? external print controler unit; it should have a small screen and menu with buttons on the front of it, and when you turn on the copier, wait about 10 seconds later turn on the print controller and be sure to watch the little screen on the print controller for the set up menu; and choose setup and from all those menus you can change the language, time and everything; ( get out your 6500 books to to which buttons are for what funtion )
Once you set up the ip address from the little buttons, you will be able to access the ip address from your computer through your browser, then you will be able to ALSO set up everything this way through the browser instead of the controller screen. Thie second way takes the least time, but you still must configure the ip add into the controller screen before you will be able to access it with the browser. One more point, after you get it all set up, the port number needs to be 9100 to be able to print from the computer to network.
and unless someone has changed it the password should be 0000 - ZEROS
I'll look for a little more info for you on this for you tomorrow.
Hope some of this helps for now
Tammy
Sbarro
06-18-2008, 04:14 PM
It's on the back of the machine and has no display.
When you switch on control panel to Printer Mode you read all info about the Fiery. It's X3e v1.1. Thats all.
We got some papers and manuals with it and on 2 of them state Pi6500 and there is not one word about 6500Pro.
We got it from German thats why :)
Humedss
06-30-2008, 03:03 AM
I think efi makes all fiery boxes.
pandorabox
04-14-2009, 01:50 PM
Fiery X3e System Software CD need
For reinstall CF2002
Plase help.
copy shop
04-14-2009, 11:09 PM
Sorry I don't Have the cd For reinstall CF2002
I only have Fiery X3e System Software CD for the Pi6500 pro system.
I have never had to do the cf2002
You may be able to try the myprintcontroller site
( chip programmer banner at the top of the copytech page)
And put in your request for your desired controller software.
pepper38_cnd
04-15-2009, 12:53 AM
Hey just send me an Email . I'll get you what you need no charge unless the file is so large it can only be delivered on dvd. thanks Tammy for the vote of confidence, business is good.
info@iuresets.com
copy shop
04-15-2009, 01:02 AM
Hi There !
No Problem....Glad to see all is going well for you !
Tammy
uscovu
03-03-2010, 06:29 PM
hi
I have a little problem with my printer Minolta CF 1501
When I turn on the printer starts to warm and he block's, the display show "system booting, please wait..."
and....that's it
So...what do I have to do? There is a back-up on the HDD's controller?
w.a.s.p.er
11-05-2010, 07:36 AM
Hy.
I am new in this site and my english is not very good.
I see ,you find a version for this fiery and if you want to help me to send this software i realy apreciate and I thank you.Your post was in 2008 but I hope you have the the file.
Sanyi
pepper38_cnd
11-05-2010, 11:24 AM
Check your PM's
lukasha
11-08-2010, 11:57 AM
Hy.
Sanyi
I join in the request...
I need to file boot.efi too...
My email is email6[at]o2.pl
Thank you
lukasha
w.a.s.p.er
11-11-2010, 10:14 AM
your email don't work,lukasha
lukasha
11-11-2010, 12:43 PM
Thank you for the information.
Please try to send lukasza83@o2.pl
Lukasha
w.a.s.p.er
11-11-2010, 01:26 PM
Look at pm
MaxMn
05-17-2011, 04:45 PM
Plase help.
I need the firmware for Fiery X3e with CF2002 too. Could someone send it to me?
killbot1000
06-24-2011, 12:22 AM
Pepper38 thank you! This was exactly what I was looking for.
seafarer76
12-31-2011, 07:12 AM
Pepper38_cnd, I have a Konica 8020 with the Fiery X3E controller attached to the back. The controller is not booting anymore. I saw in this thread that you were helping others with the firmware download. Can I get that from you as well? My email is seafarer76 at gmail.com.
Thanks.
seafarer76
01-08-2012, 05:14 AM
I just wanted to say thanks. That worked great and the controller is booting again.
Nikxxx
05-16-2012, 07:57 AM
I need the firmware for Fiery X3e for CF1501. Could someone send it to me?
JustManuals
05-16-2012, 02:47 PM
Yet another first poster wanting a handout.
CKiiza
05-16-2012, 03:11 PM
Hi. All does Anyone have Fiery X3e system software for Pro C500?
My email is aziikcaleb@gmail.com. please help me.
maharaja
06-19-2012, 12:41 PM
Hello,
I would apreciate if someone can help. We have the new Knoica Minolta bizhub C654/C754 attached to a Fiery Controller model: Fiery E100 60-55C-KM PS1.0
I need to reimage (reinstall the fiery software) on the controller but Konica is not being helpful at all and the maintainer have no idea how to do this. Can anyone please help me on how do i go about resintalling the software. I'll need manuals and software. My email address: jkerai@gmail.com
Many thanks,
Jay
mrwho
06-19-2012, 05:47 PM
Let me google that for you (http://lmgtfy.com/?q=%22konica+minolta%22+fiery+%22system+software%2 2+download)
Did I ever mention how I love this tool?
JustManuals
06-19-2012, 07:12 PM
1st post and need need need...........
vini234
10-16-2012, 07:27 PM
Hi friends.
hello friends.
I need your help, is urgent.
I have a Konica Minolta 7832 and I have the pass for access
the machine, as I suppose it will be impossible to get the keys to enter
in Command WorkStation, systema need the software (I think it is the fiery x3e), to charge, but not as loaded into the machine. I hope you can help me.
My email is: imprenta_breogan@hotmail.com
Thanks to all
Darv
01-09-2014, 12:22 PM
Uh oh....
I have a KM - C351 and the Fiery Controller will not boot. It gets to....
LILO 22.2 Loading linux-ext2.........
Uncompressing Linux OK, booting the Kernel.....
That's as far as it gets.
I'm assuming I need to re-install the software but don't have any disks etc.
Does anybody have a copy they can let me have?
Many thanks.....
Darv
Kicouarnoo
11-18-2021, 05:46 PM
Hello,
i'm french excuse my english.
I have a konica minolta 7915 cf1501 fiery x3e with "no boot device".
I have a good level in computer science and must have an IDE 2.5 HDD to replace if necessary.
I do not contribute and ask I am sorry.
I would not like to throw this copier for a dead firmware or hdd it's been months since I try to find a solution you are my last chance!
Can you help me ?
Thank you.
Synthohol
11-18-2021, 08:22 PM
I'm pretty sure I ha e boot.efi and system.efi which are the files needed to reload that fiery.
Only thing is you need a lpt to scsi cable to do it.
If you don't have one or a laptop with a printer port (not usb) your situation is at a standstill.
Back in the day I did almost 1 a week for failed fiery software.
He'll I may even have an old 3102 fiery in my basement. I'll look when I get home but I think I tossed the cable needed to do the install.
It's funny this came up, I found a new fuser for a 1501/2001 in my basement just this morning!!
Good luck finding the script cable, let me know.
