Bizhub C224 copyshop keycounter
  • Gift
    • Mar 2011
    • 2459
    Hi there Folks,
    I have a simple copy counter with reset/lock switches and counter inputs/displays for both B&W and Color (so the copyshop owner can easily see if the customer uses B&W/color or mixed). I checked the service manual and it seems that the Key Counter Connector does only provide a total count signal, not differing between B&W/col.
    So the question:
    Is there either a workaround or some kind of interface board/kit available?
    I'm not much familiar with KM, only installed key counter at some Ricoh's so far without any issues. Usually I just pick the mechanical counter signals but it seems that KM only provides one total counter *urghs*
    A hint in the right direction would really make my day
  • oldschool
    • Mar 2007
    • 245
    Re: Bizhub C224 copyshop keycounter
    You have to use the Vendor 2 interface.
    True-Count
    This will do the trick. You can order it directly through Konica Minolta P/N (76400014087)
    Jamex Tech Support: Saving the world one phone call at a time.
