Kyocera FS-1000 lights blink
  • Ari
    I hav a kyocera fs-1000 that the paper empty/paper jam indicator and the toner indicator lights blinks on and off but the printewr still prints. i got this thing from a friend and don\'t have a manual to read.
  • 10871087
    • Jan 2005
    • 1062
    Re:Kyocera FS-1000 lights blink
    there are 4 light on the front panel, if you talking about the bottom two lights flashing it indicates that the waste toner reservoir (in process unit) is almost full. Shake the process unit horizontally. Turn power off and on If the problem returns replace the process kit.
    It should be good for 100k, if you nowhere near that total then you might need to call a technician.
    • Ari
      Thanks, I gave it a shake and it\'s still doing the same thing. it still works so i will keep using it till it dies.
