what driver is for minolta di2510?
  • javier4065
    • Feb 2007
    • 251
    Hello,friends, I need Install scanner in dialta2510,for network ,What driver Should I Install it?The twain or ip thanks.Also How can I install it correctly?
  • JustManuals
    • Jan 2006
    • 9838
    Re: what driver is for minolta di2510?
    Your best bet would be to call a qualified Konica-Minolta technician. The key word there is 'qualified'
    • Kapral
      • Oct 2012
      • 43
      First thing's first - does this machine has a scanner module? Cause there are versions of Di2510 (and Di3510) without it.
      In my humble opinion - the best thing to do is to set up a small ftp server (ex. filezilla) on pc with fixed ip address and
      configure the machine through web interface to send documents to pc.
      • javier4065
        • Feb 2007
        • 251
        • Darren King
          copiertech
          • 652
          If it has the SU2 or SU3 you don't need any driver. Just set it up to scan over the network, either Email or desktop.
          If you press the SCAN button on control panel it will let you know if scan card is installed. If it reads "option needed" you don't have scan card.
          Darren
          • javier4065
            • Feb 2007
            • 251
            the copier has su2-network scan kit, what should I do first ? to install pagescope light or twain driver?.well I wait your help. thanks.
            • Darren King
              copiertech
              • 652
              You don't need to "instal" pagescope light. It is on the machine. Just log in using the machines IP address.
              • javier4065
                • Feb 2007
                • 251
                yes,your are ritght,but the customer want to scan documents and his pc had pagescope cabinet for this purpose, where can I download it the version 2.1? and if I should install driver for the scanner.thanks.
