View Full Version : Konica Bizhub C 253 C2152 Error Code
Doug James
10-04-2012, 10:47 PM
Code won't clear, Took transfer belt out and it's working OK. Is their a common fix to this problem ?
pepper38_cnd
10-04-2012, 11:28 PM
Try taking out the screw that holds the rear belt lock mechanism and replacing it with a screw 1/4 inch or shorter I have seen this screw come in contact with the gears (tranfer retracksion drive gears) behind the bracket if over tightened. Or if the wrong screw is put in after disassembly.
JustManuals
10-05-2012, 02:21 AM
Paul@justmanuals.com
Synaux
10-05-2012, 03:26 AM
"Relevant Parts:
Fusing motor (M5)
Transfer belt retraction clutch (CL7)
Transfer belt retraction sensor (PS31)
Printer control board (PRCB)"
Doug James
10-05-2012, 01:04 PM
Thanks you guys... Really appreciate your help...
Avskrap
10-05-2012, 01:24 PM
The standard fix for this is, if the belt is already factory modified per the technical notices, to tear the machine to pieces and replace the sensor mentioned by Synaux. It's located behind the main drum drive assembly. Replacing this sensor has solved the problem for me, every time.
Darren King
10-05-2012, 05:49 PM
Avskrap is right. This isn't a 20 minute job though, so don't be in a hurry. The modified sensor assembly is available from KonMin.
Darren
MFPTech
10-05-2012, 06:28 PM
Darren
The sensor's position can be adjusted by using a long screw driver .... it will save lots of time :)
173545
10-06-2012, 07:51 PM
Code won't clear, Took transfer belt out and it's working OK. Is their a common fix to this problem ? I found this helpful.
Doug James
10-07-2012, 12:03 AM
Wow... I am so grateful...
Hansoon
03-24-2014, 06:37 PM
Great tip. Had this today with a BH-C-353 one of our techs was rebuilding. Thanks to you and this wonderful panel found the solution immediately here without loosing another hour to find it myself. The screw was obstructing the white lever behind the rear locking bracket of the transfer belt.
Thanks again for taking the time to post your solution!
Hans
