View Full Version : bizhub c250 please see this....
goldencup
10-05-2012, 09:15 AM
Hi, i have bizhub C250 which is working good then suddenly the paper jams. I saw this very long rubber type of "whatever" :D about 27 inches long where is this rubber should be? :confused::confused::confused: Thank you.
17501 17503 17502
EarthKmTech
10-05-2012, 09:26 AM
that's the belt tracking rubber, there's one at each inner edge.
you need to change the transfer belt before it fails catastrophically.
goldencup
10-05-2012, 09:33 AM
Thank you for the reply sir, is this also the cause of P-21? I will replace the transfer belt, but of now i have no available belt yet, can i still use the machine or can i put back that rubber on the belt? Thank you very much
EarthKmTech
10-05-2012, 09:40 AM
The belt wont be tracking straight with just one tracking rubber. Any number of P codes will theoretically be possible.
It is impossible to put that rubber back on once it comes off. unless you have many hours of spare time to do it by hand :cool:
