di 3510 abort problem
  • goldencup
    • Nov 2008
    • 366
    Hi, any one of you have encountered this abort code on dialta 3510? Thank you very much.
  • goldencup
    • Nov 2008
    • 366
    Re: di 3510 abort problem
    Photo-0006.jpg here is the other abort taskname that appears after the machine rans out of paper.
    • Darren King
      copiertech
      • 652
      This is what the sarvice manual says.
      Device control systemfailure0x00100000to 0x001fffffMFB3 Board, FAX Board, Memory Board
      *1,
      CLAN Board*2, FN-117, JS-203, MK-1, SK-1,
      • ni311
        • May 2008
        • 658
        <Symptom>
        When Paper Empty occurs, the Abort Code "0x00101001" appears.
        <Descriptions>
        If the accumulate number of job count up over 32,276 counts, this problem occurs always. The job means copy, fax, print and scan.
        <Solution>
        Upgrade the MSC Firmware. Firmware Version: 4030-xxGx -40-xx The version is shown on the display differently. Copier model: 4030-xxG3-40-xx Fax model: 4030-xxG4-40-xx For Pi3505e/PS: Version 4030-xxG5-40-xx
        Konica Minolta Error Codes - Explanations and Solutions
        • goldencup
          • Nov 2008
          • 366
          Hi, can i just get a CF Card with a higher version from a good machine and simply replace it? Will it affect other system or part of the machine? Thank you
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            nothing other than firmware is stored on the 32mb cf card.
            rewriting it to a newer version is very easy anyway, dont know why youd want to take one from another machine.
