View Full Version : Bizhub C35 - Jamming from tray 2 only
konikilla
10-11-2012, 08:46 PM
Hi Guys,
I have loads of these little machines and have the same problem on 5 of them. It jams from tray 2 and doesn't usually get out of
the tray when it jams. Only jams every 40-50 pages. I replaced all the seperation parts the feed roll, and feed roll clutch. I've also
tried a lighter spring and a heavier spring.
When it does jam and I open the tray and turn the roller gently by hand it does move the paper despite the fact it's touching the paper.
It's like the roller isn't grippy enough.
Anyone else having this issue? I can't find any bulletins on it.
Konikilla
mmru4real
10-11-2012, 08:48 PM
Hi Guys,
Konikilla
Put a shim between the 2 trays we have done this to everyone of our machines for the same issue and it resolved the problem on 12 machines.
konikilla
10-11-2012, 08:53 PM
Hi 4real,
Sorry - Shim between 2 trays???
It only has one tray. strangely called tray 2, tray 1 is the bypass on the side.
Are you thinking of a different machine?
Koni
EarthKmTech
10-11-2012, 10:39 PM
make sure the metal plate under the separator isn't loose and sticking out catching the paper.
minimerlin
10-11-2012, 11:07 PM
Also make sure all the little stick on pad / feet are still underneath the machine, they come off very easily and the tray gets twisted.
Mita-Konica-Tech
10-12-2012, 01:28 AM
It seems every time I work on one of these toys, I always get a call back...after installing new feed rollers....for jamming.... ??? were are you putting these shims ??? mmru4real ????
EarthKmTech
10-12-2012, 10:23 AM
smaller the machine, the bigger the pain in the ass.
Windpomp
10-12-2012, 11:43 AM
Got the same problem. What is working for us is to carefully loosen the small metall plate under the feedroller and move it a bit up, maybe by 1mm at a time and test it.
I am experiencing a new problem with these machines- error code 0094 ,"2nd image transfer/retraction failure". Any suggestions on this problem?:confused:
HoonBoy
10-12-2012, 08:34 PM
Got the same problem. What is working for us is to carefully loosen the small metall plate under the feedroller and move it a bit up, maybe by 1mm at a time and test it.I am experiencing a new problem with these machines- error code 0094 ,"2nd image transfer/retraction failure". Any suggestions on this problem?:confused:error 0094 is probably the torsion coil spring or the cover/guide that don't move smoothly ("Actuator" under the transferbelt )... Check TABT1200333
konikilla
10-15-2012, 10:00 PM
Thanks for the suggestions.
I've had the loose metal plate on several machines. Fixed it with selotape.
I'll have a look at those feet and try adjusting the metal plate and let you know.
Sorry never had a 0094.
Koni
MAD0RAM
10-15-2012, 11:16 PM
Also check the tray exit sensor in the vertical transport.
I found the flag for this sensor off the keepers causing jams once in awhile.
avecosat
10-16-2012, 05:27 PM
I´ve got the same problem in four or five machines C-35 , I change the clutch and the roller and verified the sensor but the problem turn again . Solutions ? Thanks.
JustManuals
10-16-2012, 08:11 PM
Paul@justmanuals.com
mmru4real
02-08-2013, 11:08 PM
The shim should be on the left side near the front cornercorner between tray 2 and 3. I can post pictures next week, it has fixed every machine we have that has the additional tray
paper jam transfer on two printers,40p(new) and 4650,before i start to replace cl1,cl2 and cl3.do you have any suggestion?
tech51
02-10-2013, 03:22 PM
I would suggest posting a new thread so that more people see your fault.
mmru4real
02-21-2013, 11:00 PM
Shim would go almost directly below power switch.
scottybbb
02-22-2013, 12:43 AM
Can you post a picture of the shim and where you are installing it?Thanks.
mmru4real
03-02-2013, 02:00 AM
we have used paper shim and wooden shim please see attached pics
