View Full Version : Miscellaneous Konica Minolta 7272 - Doest Not Print From Computer
shahid ahmed
10-12-2012, 07:04 AM
Recently I have purchased Konica Minolta 7272 Machine, its fine. I have installed the driver IP511A however, it does not print when I desire. You are requested to please help me in this regard
Shahid Ahmed
Darren King
10-12-2012, 05:34 PM
Riiiiiiiiiight!
You are requested to enter IP address into copier.
shahid ahmed
10-12-2012, 05:44 PM
Riiiiiiiiiight!
IP address is already entered in the machine, however, I am trying to contact through Parrell Printer Cable is it possible?
Darren King
10-12-2012, 06:09 PM
I can't help you there. I have only used network printing on these.
JustManuals
10-12-2012, 08:39 PM
Paul@justmanuals.com
minimerlin
10-12-2012, 09:16 PM
ThanksThe parallel connector does not allow printing, if I remember correctly it is for updates! I maybe wrong I am only human!
RRodgers
10-12-2012, 09:19 PM
Did you get the $1500 print chip with your copier? I would "guess" probably not. No chip, no print.
pepper38_cnd
10-12-2012, 09:36 PM
The Ip-511A is a big bubble that hangs on the back of the copier. If you go to printer and settings on the machine control panel you should be able to print a test page if you can't then you probably do not have the optional IP-511A. The network port on the main body is only used for scanning.
Synaux
10-17-2012, 01:17 AM
Request Received.
Assuming you actually do have the IP-511A physically installed and you want to print via Ethernet you must set the port (ip address in printer settings) to LPR1.
Otherwise, parallel is garbage and I have not even tried to print to parallel for several years now.
I would guess that minimerlin is correct, but if he isn't you probably would have to fiddle with the parallel port settings in BIOS
