View Full Version : samsung allin one need help
skumar
01-04-2008, 07:40 PM
hi
my samsung scx 4216f all in one showing " toner empty " i change new one than again same plz help me
skumar
Hombre
01-09-2008, 02:23 PM
hi
skumar
Hi,
It should have a fuse on the cartridge. Put a new fuse. Original fuse is 63mA, but I tested with 250mA fuse and it worked (although did not burned the fuse, but the machine recognized cartridge as new).
skumar
01-09-2008, 06:19 PM
hy
thanks for ur suggation at last i got the prosiger for resating 1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
If problem persists, there may actually be a problem with either the toner cartridge or the SCX-4216F.
Works for SCX-4521F
