Konica Minolta Bizhub C220 SMB Scan to shared folder - "Server Connection Error"
  • sulabh
    • Oct 2012
    • 15
    [Error Code] Konica Minolta Bizhub C220 SMB Scan to shared folder - "Server Connection Error"
    I had a SMB scan to a shared folder. It was working fine till yesterday. i donno what happened to it since today morning whenever i try to scan a document it represents a failure and error details shows up "Server Connection Error"
    Plz Help me as soon as possible.
  • emujo
    • Jun 2009
    • 3009
    Re: Konica Minolta Bizhub C220 SMB Scan to shared folder - "Server Connection Error"
    More than likely, your computor has recieved a new IP address and now the one touch button setup to scan back to 192.168.x.x can no longer find that workstation. If you can still print to the device then we can establish communication. If you don't know what you are doing, call a KM tech out to fix it. I would also suggest that you scan back to "Host name" versus IP address.
    • 8050
      • 88
      1st are you scanning to only 1 pc or more? Or are you scanning to the server? "Server Connection Error" means the C220 cannot contact the SMB PC. There are a few reasons why you would get that error. 1st do you still have internet connection? 2nd: was the shared folder moved or renamed? 3rd: were the share properties or permission changed? Firewalls can also affect SMB.
      • sulabh
        • Oct 2012
        • 15
        emujo: Yes i can print documents & no my computer hasnt received any new ip!!8050: yes i am scanning to only 1 pc. Yeah i still have internet connection. No the shared folder wasnt moved or renamed. No share properties or permission has changed.
        • Shadow
          PHD in Sh!t Disturbing
          • Sep 2011
          • 455
          change the address to the computer name and double check your password.
          the leading cause for that failure is incorrect spelling or changed passwords.
          this happens quite frequently when passwords are changed on a regular basis.
          just something else to check.
          $hit Happens - Deal with it and move on.....................................sigpic....................................Lock & Load
          • sulabh
            • Oct 2012
            • 15
            what do you mean by changing the address to the computer name please explain fast and i dont have a password.
            • Darren King
              copiertech
              • 652
              If you go to a command prompt on the computer and type in "hostname" (without the quotes) it will give you the name of the computer. I think you have to set up DNS if you scan to hostname. Although I could be wrong about that.
              Darren
              • TheOwl
                • Nov 2008
                • 1732
                Darren
                DNS stands for Domain Name System and is a requirement for a computer or domain name to be resolved to an IP address. When using names rather than IP addresses, you are essentially still using an IP address for the communication, but the DNS server provides the updated IP address.
                As for the scanning issues, try disabling your AV / Firewall as you may have recieved an update to the software that is causing the connection error. If this is the case, then speak with the software provider on how to create an exception for your copier. On the flip side, it may have also been a MS Update on your PC, but that will be very hard to track down.
                Other things to look at:
                1. Ensure that the One Touch button is correctly configured with the Path and User credentials
                2. If you don't use a password for the copier to scan with, create an account for it to use with a password
                3. Ensure the copier can see your computer by going to Admin Settings > Network Settings > Detail Seting > Ping Confirmation
                4. Ensure that the share is still visable on the network via another computer or locally (\\localhost\sharename)
                5. Ensure that Windows is correctly configured for a Home or Work network otherwise file sharing will be turned off (Windows Vista and Up)
                • wseyller
                  • Sep 2012
                  • 1129
                  Sometimes depending on the situation I will create a new local user account on the computer usually named "bizhub" with a password. Create a folder on the C drive named "scans" and set the permissions. The set the hostname of computer and the new username/password in pagescope. In pagescope i type in"scans" to where the folder location is. This way you can be sure the login credentials are right. You just create a shortcut to the scans folder on the desktop of the users normal local account.
                  Sent from my DROID BIONIC using Tapatalk 2
                  • sulabh
                    • Oct 2012
                    • 15
                    Hey darren, i use ip address to connect my machine to the system.. But the host name in the machine and the hostname of ma pc differs. Could any of you help me in setting up the machine settings from the begginng???
                    • sulabh
                      • Oct 2012
                      • 15
                      The owl, could you plz tell me how to check the One touch button in configured correctly or not..!!!
                      Before also i was using without a password and a different account, so i dont think i want to create a mess by creating an account for it.
                      as per you said about the ping confirmation, when i accessed it there were no ip in the ping confirmation, i entered my pc's ip and the ping was perfect.
                      yeah the share is visible on the network.
                      windows is configured correctly for a home or work network, though i would appreciate if you could also help me with it..!!!
                      thx for ur reply
                      awaiting for your reply
                      • TheOwl
                        • Nov 2008
                        • 1732
                        thx for ur reply
                        Windows networking with the Windows Vista and up got a little more complicated as they introduced network areas. If you connected to a network and said that it was a public area once connected to it, then Windows would tighten up the firewall and disable a bunch of features such as file sharing.
                        If you click on the network logo in the bottom right and click on Open Network and Sharing Center, you should then be able to adjust the connected network and the Advanced Sharing Settings.
                        As for the One Touch button, I am assuming that when you walk up to the machine and press Fax/Scan, you are then presented with a button that you press which basically tells the machine to "scan to this destination" and then press start. To adjust that button, go into the web interface of the machine (type the IP address of the machine in Internet Explorer or something similar) and then click on Store or Store Address. You should then find that One Touch button in that list whereby you can then edit the button to match the details on your computer.
                        • johskar
                          Solutions Engineer
                          • Mar 2011
                          • 22
                          The Bizhubs are capable of usilizing both DNS and Netbios name for SMB scanning.
                          Iirc, if you type only the hostname in UPPERCASE/CAPITAL letters it goes NETBIOS first, if in lowercase, it goes dns.
                          Scanning to netbios hostsname sure works fine the times I've tried, even without a DNS that gets hostsnames fed from a DHCP.
                          if NTLM is set to wrong version that can cause server connection errors too in some cases, even tho it worked just fine the day before.
                          The wonderful thing about standards is that there are so many of them to choose from.
                          Yes, I got ADHD, my posting can be quite chaotic at times!
                          • sulabh
                            • Oct 2012
                            • 15
                            hey johskar, I guess the NTLM problem is causing a problem for my scan.. could you help me with that????
                            • sulabh
                              • Oct 2012
                              • 15
                              I checked my machine settings and even ma pc settings all is correct.. i have disabled my windows firewall so that no complications can arise..
                              As johskar said about the NTLM.. I might b the problem.. if you could help me in that.. i would appreciate it..!!!
                              thx
