View Full Version : Bizhub C220 keeps restarting
Bullet71
10-26-2012, 05:52 AM
Hi we have a C220 which after a few seconds keeps shutting off and restarting. We have tried a different power supply and memory chip but still does it. The machine doesnt stay on long enough to do the firmware. Any ideas?
HoonBoy
10-26-2012, 01:35 PM
I had the same issue.... replacing the MFP Board solved the problem...
JustManuals
10-26-2012, 08:15 PM
Paul@justmanuals.com
Jumping Jack Flash
10-26-2012, 10:59 PM
Hi
Proceed as follows:
Remove the NVRAM and turn the copier.
If you start and stop the hourglass, it means that the board is working.
Nvram data not fix.
Can I help you should set the cause.
TheOwl
10-28-2012, 11:45 PM
Try doing the firmware straight up and see if that helps to resolve your issue.
Bullet71
10-29-2012, 06:27 AM
The machine does not stay on long enough to write the firmware, have ordered a mfp board.
Bullet71
11-02-2012, 10:00 AM
Changed the Mfp board on this machine and all is fine now.
