View Full Version : konica minolta 250 cl3 replacement
DOE
11-01-2012, 05:10 PM
can anyone tell me how to get to the first drawer feed clutch. i have not worked on the 250 much so i am not real familiar. i took out the first feed unit and can see it back there but have not been able to get to it from any direction. i am probably overlooking the easy way. paper will not feed from first drawer. thank you for any ideas.
kingarthur
11-01-2012, 05:40 PM
you need to remove the bypass completely, then the 2nd tray feed unit, then you can remove the feed unit, you'll need to remove the back cover when you reassemble it, to reconnect the connector
Hansoon
11-01-2012, 07:00 PM
Why are you guys replacing those clutches so often? We just blow them out with compressed air and than soak them with brake cleaner. Blow the liquid out again after a minute that's it.
With hard to reach clutches we even try to do this in the machine sometimes.
Hans
JR2ALTA
11-01-2012, 07:05 PM
I'd rather replace the clutch than "soak it in brake fluid"
No creativity points.
It's possible to plug in without taking off back cover. The whole thing is a pain
Hansoon
11-01-2012, 07:10 PM
Works well, believe me. Doing this since the EP-5400 / 4050 / 5000 / Di-550 years without problems.
As long as they are not sticky from residual magnetism it works and even in that case they can be demagnetized with an AC coil.
We are Indys not a big company and have to cut costs by any means. Those clutches are not the cheapest.
Hans
EarthKmTech
11-01-2012, 10:07 PM
those clutches are under $10, they go straight in the bin with the slightest doubt with me.
Also, i have replaced the tray 1 feed clutch in situe with minimal disassembly, but it requires advanced contortionist skills. (like most things designed by the japs)
Darren King
11-02-2012, 02:17 AM
Hans
It is way cheaper to replace it the first time than to have to drive back three days later and take it all apart again.
Darren
JustManuals
11-02-2012, 03:34 AM
Paul@justmanuals.com
JR2ALTA
11-02-2012, 04:34 AM
This PITA clutch reminds me of a helpful hint!
When a e-clip is at risk of falling put a dab of grease on it. it will stick in place letting you clamp it down with one hand.
Hansoon
11-02-2012, 04:36 AM
Are we talking about the same clutches.......??
http://www.precisionroller.com/9322-1000-81-for-konica-minolta/part_number.html
Hans
JR2ALTA
11-02-2012, 04:46 AM
Nope.
Results for 9322 1500 12 (http://www.precisionroller.com/search.php?q=9322+1500+12&x=0&y=0)
Should be cheaper OEM
Hansoon
11-02-2012, 05:13 AM
Yes, but not under 10 US$.......
Hans
johskar
11-02-2012, 08:53 AM
over here those would cost a customer $19.5 +vat so they can't be that expensive... looks to me like someone is making alot of money on them...
EarthKmTech
11-02-2012, 08:54 AM
i work for the manufacturer - our parts prices are lower than EVERYONE elses ;)
and yes, they are under $10 for us.
DOE
11-05-2012, 05:53 PM
thanks everyone. the brake fluid did work. apreciate the help
Hansoon
11-05-2012, 07:35 PM
Did you say "Brake Fluid" ??????
:confused:
Hans
