software to retrieve password
  • Lasersupplies
    • Jul 2011
    • 221
    Hi,
    I just purchased a c451 for the office. I need to get into the service menu (Stop, 0, 0, stop, 0, 1) but then i am told i need to input a password. Does anyone know how this can be wiped or is there any software that can retrieve the current password?
    Hope to hear from one of the techs soon, thanks.
  • havokprod
    • Oct 2012
    • 159
    Re: software to retrieve password
    Have you tried "92729272" ??
    • nmfaxman
      • 1702
      Try 00000000 or 12345678.
      Same as admin code.
      • TheOwl
        • Nov 2008
        • 1732
        As above assuming that the password hasn't changed. By default, those machines used 12345678 as the CE Service Password.
        If those passwords don't work, then you are going to have to contact the people that used to service the machine as the only way I am aware of resetting that password is by replacing the NVRAM which is something that Konica Minolta don't release without a good case for replacing it as it zeros the meter reading.
        • Synaux
          • Mar 2012
          • 1224
          Originally posted by TheOwl
          As above assuming that the password hasn't changed. By default, those machines used 12345678 as the CE Service Password.If those passwords don't work, then you are going to have to contact the people that used to service the machine as the only way I am aware of resetting that password is by replacing the NVRAM which is something that Konica Minolta don't release without a good case for replacing it as it zeros the meter reading.
          What about flashing the NVRAM?
          • habik
            • 2013
            Flashing should work. Find the NV RAM Recovery firmware on KMBT site as Synaux suggested!!
            Firmwares HERE
            • ni311
              • May 2008
              • 658
              If you want to ask KM to replace your NVRAM, you should have a pretty good reason for that, I don't believe it will replace it just for a lost password. Also, you should give them your NVRAM and then expect a new one in return. You can bet that they are quite strict about this subject. I'm not sure that using NVRAM Recovery Tool will erase your service password but you can try it and let us know It sounds much easy just to contact the person from who you bought the copier and just ask for the password.
              Konica Minolta Error Codes - Explanations and Solutions
              • Synaux
                • Mar 2012
                • 1224
                I just have a random thought, perhaps someone with more experience on these nvram chips could elaborate.
                Would all the personalized data be reset to the defaults if one were to de-solder the battery out and re-solder/replace?
                If so, I would suspect that the password would be reset to defaults with everything else. Or is this just a terrible idea?
                • ni311
                  • May 2008
                  • 658
                  It is a terrible idea, actually... At least, for the printing production series all the data will be corrupted and you won't be able to use the printer without a new NVRAM. To make a long story short, someone by accident removed the NVRAM battery; we try to solder the battery back but when we started the machine, a service password was asked (even tough was never set before) and some strange characters were appearing on screen.
                  • habik
                    • 2013
                    No matter what you do, without NV RAM recovery FW and Security Codes you hardly bring it back to life, which you will not find anywhere on the net as they are generated for every machine at the factory, you want be able to get your m/c back to life so consider your options and be wise what you doing!
                    Be very wise!! that is all I can recommend. We ended up with a machine that is now only for spares as we were trying to be smart!
                    Firmwares HERE
                    • ni311
                      • May 2008
                      • 658
                      Indeed, the only solution to our nvram battery adventure was to replace the nvram with a new one from km. but first, you have to send the defective one to them.
                      • Synaux
                        • Mar 2012
                        • 1224
                        I see. Thanks for the replies guys.
                        • johnyb
                          • Feb 2011
                          • 167
                          GCQ-J8,GDQ-J8,GEQ-J8 firmware, this will clear the NVRAM.
                          • habik
                            • 2013
                            Yes, it will, however after, you will need the Security Codes if the battery was out.
                            Firmwares HERE
