View Full Version : Konica 7130 F-36-4
CWalls
01-09-2008, 06:12 PM
Need help with this code F-36-4, recently replace a idler gear for the fuser unit after that it started showing that message.
any help would be apreciated
Thank you.
skumar
01-09-2008, 06:40 PM
hi
f36-4 is open thermistor2
skumar
CWalls
01-09-2008, 10:29 PM
thank's i double check it and the message is still coming up any idea?
dogsbody
01-09-2008, 10:57 PM
I don't muck around with these things the temp sensors fail if you look at them sideways and when the thermostat wears it will chew into the upper (heat) roller. Then you will have to reset the temp code.
pepper38_cnd
01-15-2008, 12:48 PM
Maybe you removed the fuser with the power still on, when you changed the gear? Now you have a code, you must resset the code in 25 mode to clear it.
bushy
01-18-2008, 03:05 AM
go to 25 mode dip switch 3 bit 1 put in a 0
azherm
01-18-2008, 07:38 AM
F34, F35 & F36 codes must be reset using 25 mode.
Dipswith 3, bit 1 is the fuser reset command
0 is no
And 1 is yes
You must reset a fuser fault:)
cgeorge
01-18-2008, 07:53 PM
I have the same deal going on with a Konica 1015. I am not a copier tech but our company is having me fix this copier since our local company was unable to fix it. I had to change the fuser. How do I get into mode 25? Dipswitch 3, bit 1, What is this and how do I do this?
Thanks,
Curtis
