View Full Version : Miscellaneous C454 set max copies made at 1 time
mikez
11-15-2012, 11:04 PM
Is there a way to limit the amount of copies that can be made at 1 time. Customer keyed in 7000 copies on accident. Now they want a limit of 50 at time.
MAD0RAM
11-15-2012, 11:59 PM
Perfect example of over compensating for one stupid action.
And I dont think you can limit the copy amount.
You could limit the amount total in authentication.
mikez
11-16-2012, 04:05 PM
I didn't think there was either but i thought I'd ask. Thanks
pepper38_cnd
11-17-2012, 04:12 PM
Tell the obviously intelligent customer. You can disable all the paper trays except the bypass that way everyone would be limited to the number of sheets the bypass holds. Or he/she could just explain to the operators that pressing any number followed by the "0" key three times then pressing start key is going to result in over 1000 copies. Or you can explain that "As a Tech, stupidity has no technical solution!"
