Bizhub 200 Paper Tray Message
  • JR2ALTA
    • Feb 2010
    • 2033
    Tray two will stop feeding and panel will read
    "Pull out Selected tray and load paper" like it wants a different size or type.
    It does not say "replenish paper", either way there is paper.
    I rebuilt feed unit to cover feed wheels, clutches.
    I guess it could be that ridiculous sensor box or the main board.
    Thanks in advance!
  • MAD0RAM
    • Oct 2012
    • 81
    Re: Bizhub 200 Paper Tray Message
    Try the registration clutch.
    I know it sounds funny but I saw this in the solution data base and it fixed my issue.
    • JR2ALTA
      • Feb 2010
      • 2033
      Yes I know of the clutch for add paper, this one seems different tho. Can't hurt to try
      • MAD0RAM
        • Oct 2012
        • 81
        Solution ID TAUS0801927EN* Solution Usage 2
        Description
        When feeding from any tray, at least 3 pages are output. After a minimum of 3 pages exit the machine, the display prompts the user to load paper in the tray.
        The tray still has paper loaded. Opening and closing the tray will start the job again.
        Solution
        CAUSE: Synchronizing Roller Clutch has failed.
        SOLUTION: Replace Synchronizing Roller Clutch (p/n 9322100081).
        SPECIAL NOTE : Solution contribution by Rick Johnson, Midwest Region DSM/SSD
        • JR2ALTA
          • Feb 2010
          • 2033
          Damn I had one too.
          I've seen that too some reason I thought it was "replenish"
          • nmfaxman
            • 1702
            I would look at the drawer lock or paper size sensor contacts.
            Sync clutch just doesn't make sense to me.
            A bad sync clutch you give a jam indicator or varying lead edge and would happen on all drawers.
            A drawer that loses paper size input would stop and tell you to load correct size or reset drawer.
            Tape the drawer shut and run 500 single sided while watching the lead edge void.
            Just copy the front edge of the test pattern to save toner.
            Run 500 after removing the tape and see if it comes back.
            As always...................................
            • MAD0RAM
              • Oct 2012
              • 81
              That will cost you two reams of paper and a $50.00 sync clutch.
              • wseyller
                • Sep 2012
                • 1129
                Ive seen where the fingers on the paper size sensing unit where in between touching and not touching causing all kinds of paper sensing issues. There is an I/O test for this in service mode . In one case i had to bend the fingers out a bit so the tray would actuate the sensors properly.
                Sent from my XT875 using Tapatalk 2
                • MAD0RAM
                  • Oct 2012
                  • 81
                  JR2ALTA let us know what worked when you get it working.
                  • pepper38_cnd
                    Field Service Manager
                    • Aug 2005
                    • 1075
                    Cracked paper tray? Front right corner. Install reinforcing plate 4030P00100 and replace the tray latch.
                    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
                    Now into Ip TV KODI Boxes
                    • Darren King
                      copiertech
                      • 652
                      My money is on the registration clutch.
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        I brought registration clutch, sensor assembly and main board.
                        It was not the clutch. Feed one sheet and screen read "pull out selected tray and load paper".
                        To be sure I ran machine with one sheet in cassette and the proper message appeared "replenish paper".
                        Replaced the main board next and she ran all day. Didn't need to mess with that silly ass sensor box.
                        Thanks guys
                        • JR2ALTA
                          • Feb 2010
                          • 2033
                          Thanks guys
                          • MAD0RAM
                            • Oct 2012
                            • 81
                            Thats why we get paid the big bucks. Our service manuals and solution data bases are not always the final solution.
                            • Mr. Joshua
                              • Nov 2011
                              • 31
                              Thanks for the update. I would have bet on the reg clutch. I will add this to my notes!
