View Full Version : Konica Minolta Bizhub C220
PEPELEMU
11-19-2012, 11:43 AM
I am buying a Konica bizhub c220 from my used copier distributor and the machine has an error, no animation guide data available. I need to get the movie.exe file. I am not a konica dealer. I am a independent service company in NH. Is there any way to get the file if you are not a konica dealer?
Thank you
John
jotunn
11-19-2012, 12:26 PM
You've got PM.
JustManuals
11-19-2012, 09:45 PM
Paul@justmanuals.com
jarobb
12-18-2012, 12:40 PM
google: A0ED0Y0-A000-G00-01_2nd_Movie.exe
or link: Source (http://rapidlibrary.com/source.php?file=ulcnwwz8eyi89on&url=http%3A%2F%2Fcsesftp.konicaminolta.eu%2Ffiles% 2FDL%2F201001%2F18150909%2FA0ED0Y0-A000-G00-01_2nd_Movie.exe&sec=3801c1a7ed5db774)
85,8MB
Darren King
12-18-2012, 05:21 PM
If you can't find it the machine will work fine without it.
ni311
12-18-2012, 06:27 PM
It will display a message about it, this is all. It depends on the client, some will ignore it, other will believe the machine is broken and you have to fix it...
jarobb
12-18-2012, 07:15 PM
Download movie.exe file from link above (this .exe file is self extract file), unzip. You get a .tar file.
.tar file save into the root directory of a USB memory device. Connect the USB memory device to the machine USB port (service USB port is under a metal cover after USB ports of device.)
Select the key as follows.(in service mode)
[System 2] → [→] → [Install Data].
Touch [Movie Data]
Touch [Set].
Press the Start key to install the data.
Check result “OK” is displayed and touch [END].
Darren King
12-19-2012, 01:17 AM
Touch [Movie Data]
Touch [Set].
You don't use the service USB port. You use the port next to the control panel.
Darren
blackcat4866
12-19-2012, 01:30 AM
About the only thing I can add to this discussion is the "why?". The HDD was formatted to remove any remnants of the activity log or recent documents. The movie data was just a casualty of the re-formatting. =^..^=
jonbonse
03-09-2016, 03:52 PM
Thank you
John
Hi, I have bought a second hand machine with the same problem, do you have the 'movie.exe'?
Ciomu
03-09-2016, 08:02 PM
Check your pm.
Have fun.
Ciomu
03-09-2016, 08:07 PM
check youre pm
