View Full Version : bizhub 250 with a 0x00900000
brent
11-19-2012, 11:00 PM
this is a new code to me. I am going to get on it later tomorrow in the field. any advice or heads up?
0x00900000 abort. thanks for any advice.
brent
JR2ALTA
11-19-2012, 11:03 PM
Windows 7 print job stuck.
Clear queue on computer, set port from LPR to RAW in driver
Mick01
11-19-2012, 11:56 PM
Abort code 0x00900000 is related to fax so i assume that an FK-503 is installed in this machine.
As a trouble-shooting procedure, please try the following:
1. Enter Utility/Counter -> Admin. Management -> Enter the Administrator Code -> Admin 1 -> TX Setting -> Quality/Mode -> Communication Mode -> Change from Fax(G3) to PC + E-Mail. Check if fault still re-occurs.
2. Remove the FAXS board and check if fault still re-occurs.
3. Remove the MEM board and check if fault still re-occurs
Hope this helps
brent
11-20-2012, 03:55 PM
ok great. I am going to check it out right now and I will report back. thanks
brent
brent
11-20-2012, 05:07 PM
well I get the dumb shit award today. can I say that?
the connector going into the fax board was slightly unplugged
tripping the code every time. machine is fixed. I am happy
but sheepish that I didnt seeit
thanks
brent
Hansoon
11-20-2012, 05:32 PM
Don't worry, happened to me once too. I had to drive 120km into the Black Forest however for that. One week before I had a failing Printhead with the same machine..........
Hans
JR2ALTA
11-20-2012, 06:24 PM
good to hear, sorry I jumped the gun.
brent
11-20-2012, 07:18 PM
you did not jump the gun. you tried to help. I am grateful
brent
Mick01
11-21-2012, 01:56 AM
Great to hear you got the machine operational. Good job
Regards
Michael
