error code E04-1 DP6010
  • thienquansgs
    • May 2025
    hello ! i am a technical ricoh. my copy is panasonic DP 6010 .i see problem arlam E04-1. i was check thermistor ,thermotas , lamp ,and connect all good. when i switch power on then lamp fuser to open about 3 second and off concomitant arlam error code E04-1. i can't enter mode simulation with key "funtion + original size + 3 " in service handbook .what to do? please give me one solution good . thanks everybody .
  • hosennet
    • Mar 2007
    • 145
    Check Points
    1. Fuser Thermistor is dirty.
    2. Thermistor position is incorrect.
    3. Fuser temperature is low. (Adjust F6-31)
    4. Thermistor is defective.
    5. Fuser Lamp connector is disconnected.
    6. Fuser Thermostat is defective.
    7. Fuser Lamp is defective.
    8. HTC PCB connector is disconnected.
    9. HTC PCB is defective
    • thienquansgs
      help me please !!!!
      Originally posted by hosennet
      Check Points
      thanks hosennet was help me !!! i think that is fuser temperature is low because when i switch power on then lamp light about 3s and off .but i don't know why i can't enter mode simulation.i have service handbook but i can't enter mode .
      • just a tech
        • Jan 2007
        • 332
        press "function"..while holding down "function"-- press "original size"..while holding down "function" and "original size"-- press the #3 on the #pad.. to exit menu mode press "function" and while holding it down press the "clear" button...
        • thienquansgs
          i don't complete . please help me !!!
          thanks you ! i was enter mode possible . and press f6 continue 31 and ajustment from 0 --> 15 but can't complete. if themistor ,thermotast ,and lamp is disconnect then lamp don't light. but lamp light about 3s then off .i do careful that it. phease help me.
          • yakyitz
            • 242
            e4-01 error code
            please read the attached bulletin an update if your machine serial number is within range of those affected machines
