View Full Version : Electrical TA300ci - no cyan and weird blue marks on prints and copies (see sample)!
Estico
11-26-2012, 08:31 PM
just replaced Cyan Drum, Dev and Transfer Belt - same result! Any idea? Thanks.
kyrenecopy
11-26-2012, 10:13 PM
What was the original call for? And am I missing something here, I see cyan on the test sheet you attached?
Tonerkiller
11-26-2012, 10:25 PM
The color cleaning motor is not turning. Turn machine off, take the back cover off, turn on machine and all motors should spin. Replace the ones that are not turning.
Estico
11-26-2012, 10:36 PM
the original call was for blue dots - replaced cyan drum then got no cyan on color belt U089 - only the blue marks... After that we tried new cyan drum, dev and transfer belt - no result.
JustManuals
11-26-2012, 10:53 PM
This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
Paul@justmanuals.com
madas
11-27-2012, 02:12 AM
I have seen a similar fault on other models as a main charge issue.
madas
blackcat4866
11-27-2012, 02:24 AM
madas
I'm with madas on this one. If the interval is 38.9mm it's the primary charge roller arcing.
Did you replace just the cyan drum, or the cyan drum unit assembly (which includes the primary charge unit)? New parts or used? =^..^=
madas
11-27-2012, 02:33 AM
Here's a couple of samples I have of this fault.
madas
dyodyo
11-27-2012, 01:21 PM
If you already replaced Drum Unit, Dev. Unit and Transfer Belt and the result is the same as you said then check the values of U100 (Adjust DC2)? Maybe somebody mess around with the settings.
Tonerkiller
11-27-2012, 02:05 PM
It still looks to me like the cyan drum is not cleaned. The waste toner builds up on top of the drum unit and the tran belt rubbs on that toner and leaves marks on all prints.
Estico
11-27-2012, 02:11 PM
yep - i replaced the cyan drum unit assembly, cyan dev and transfer belt. Also swapped out with Yellow drum (which includes the main charger) - same result.
Estico
11-27-2012, 02:18 PM
I checked the high voltage and bias values -everything looks normal. We’ll go back tomorrow and take it apart…
ccwilliams3
11-29-2012, 12:58 AM
What about the color cleaning motor?
Estico
11-29-2012, 01:11 AM
We fixed it today - the board interface where the color drums and devs connects was causing the faulty ground issue (blue marks on prints). Thanks everyone!
blackcat4866
11-29-2012, 02:31 AM
Thanks for sharing. =^..^=
dyodyo
11-29-2012, 04:04 AM
Nice one! Thanks for the info!
