If the m/c previously had a sorter then the conveyor unit may still be installed
If not then there is a gear on the delivery rollers that wears unfortunately you have to strip boards etc from rear of m/c to get at it
But first check that the pressure rollers on top of the delivery rollers have not been dislodged by the customer
They are a simple spring loaded affair that you will see when you open the clamshel
