View Full Version : cleaning drum 101?
jewen25
12-07-2012, 08:53 AM
what is the best to clean drum surface is there any way to wipe out the scratch? or what solution we need? any idea
monstott2010
12-07-2012, 04:54 PM
If the surface is scratched, you can clean it off by replacing the drum... if there is material on the drum such as label goo, you can sometimes clean off with a soft white cloth, but be gentle so you don't scratch the drum and have to revert back to step one...:D
I havn't tried to take a line out but have used Meguiar's clear coat rubbing compound to bring back a drum from voids on the copy...The drum looked hazy before the polish....after the polish I used WD40...I also use the WD40 to wipe off any toner,etc stuck to the drum...only on 2050's, 2550's and 2560's so far.
