View Full Version : Biz C 6000 yellow problems...
remati
12-12-2012, 11:11 PM
Hello people
problems with yellow bands visible in grayish
-Any idea for this
best regards
Mick01
12-13-2012, 12:56 AM
Try a Different screen (LINE 1 or Line 2)
also try different screen frequencies for the line you are using. Lower frequency equals smoother colour
Kind regards.
methogod
12-13-2012, 02:10 AM
i would try differnt settings to black processing. Most times it best to print to HOLD, then edit on the fiery.
Properties...
Color...
Basic Setting...
at the bottom --- "grey and black"
see if changing them to different settings helps with your grey issue.
what are you printing, sometimes RGB projects from shitty programs like PUBLISHER never look right.
upload item you are printing for more specific help...
its trial and error no matter what.
ni311
12-17-2012, 07:39 PM
Trying to change the screening is the fastest way to solve it. If not, try in Service Mode to run Auto Gamma Adjustment and Printer Gamma Offset Adjustment.
methogod
12-17-2012, 08:23 PM
if none of this fix it, i would think you DV is weak, or worn out, or your drums are close as well.
mike
ni311
12-18-2012, 08:34 AM
or the charging assy...
methogod
12-18-2012, 11:24 AM
I would think that is the first thing to replace on any color issue.
I would think if the conrona's are due or even close i would change them, they are cheap parts. I never let the corona's go longer then 50K - i get them from KATUN they work well and are just as good as OEM.
ni311
12-18-2012, 06:37 PM
Just switch items from different colors between them, it's the easiest way to separate the problem.
