View Full Version : C7000 code C2804 help.
oscar
12-13-2012, 08:59 PM
Hello to a problem in a giving C7000 C2804, already swapped the bar IDC,develop, make adjustments and try anything. not only changed the PRCB still you have any other tips?
HoonBoy
12-13-2012, 09:17 PM
How does a test print 1 look at 255 if you turn off auto gamma adjustment(dipssw), solid black or grey?
Had this problem on a Bizhub C5501 and black was grey and also had a C2804 code... ended up being HV1, replacing solved the problem...
Mick01
12-13-2012, 11:32 PM
I agree it appears to be a HV1 issue. I would caution though on using test pattern 1. Always use test pattern 53. The reason being test pattern 1 does not apply any screening to the print (line or dot screen). 8050 and C500 are different (uses test pattern 1).
Try Test pattern 53 with black at 255.
