View Full Version : C252 blank magenta copies
repeatcopiers
12-14-2012, 04:00 PM
I have a C252 in the field that gives a blank magenta copy. We replace the magenta drum unit and still same issue.
wseyller
12-14-2012, 08:08 PM
Check to see if laser from write unit is blocked.
Sent from my XT875 using Tapatalk 2
MAD0RAM
12-15-2012, 12:34 AM
Or the primary transfer roller may be out of place on the transfer belt.
EarthKmTech
12-15-2012, 12:53 AM
if none of the above first, it will be the HV board, then failing that the PWB-M
(assuming some d/h hasn't damaged the flat ribbon cable to the laser relay board when changing a main motor in the past)
wseyller
12-15-2012, 02:24 PM
I would print some magenta rich pages and stop the machine half way to see if the image is on the drum or not. That could eliminate the drum and write unit.
