View Full Version : 7075/FORCE 75/7085 Technical Bulletin #15
sunsetoutpost
12-17-2012, 04:34 PM
Anybody have a copy of this tech bulletin?
mrwho
12-17-2012, 04:42 PM
I have some troubleshooting data on those models - what is the problem you're having?
sunsetoutpost
12-17-2012, 05:20 PM
Light image across second side of 11x17 sheet.
methogod
12-17-2012, 05:26 PM
just like 920s but those bulletins are not posted any more. best i can do is all for this model.
https://www.dropbox.com/s/7c0ownbvoj2k60a/7085.pdf
more info maybe we can help..
ni311
12-17-2012, 05:36 PM
I hope these two will help you:
[I] TAUS0629125EN00
Publisher
[Company]
BUS
[Group]
BUS_QSS
Contents
[Original Doc. No.]
[Open Date]
30.07.2006 13:30:43
[Doc. Language]
English
[Doc. Priority]
Normal
[Product Name]
7075
[Option]
[Subject]
Light areas and voids on 11x17 trail edge, second side of duplexed copies only.
[Description]
[Solution]
CAUSE : The paper reverse/exit section has dislodged or become loose due to the exit mount plate mount screws loosen. This causes inconsistent pressure and causes excessive loop as the 11x17 enters the ADU section and causes the excessive loop to create the light or void areas on the second side of copies.
SOLUTION: Tighten the the exit plate mount screws and apply a drop of thread lock to prevent reoccurrence.
SPECIAL NOTE: Solution provided by MARK LUITEN, INTEGRATED OFFICE SOLUTIONS, INC.
[I] TAUS0614623EN00
Publisher
[Company]
BUS
[Group]
BUS_QSS
Contents
[Original Doc. No.]
[Open Date]
30.07.2006 13:07:32
[Doc. Language]
English
[Doc. Priority]
Normal
[Product Name]
7075
[Option]
[Subject]
Faded image on lead and trail edges of second side of 11x17 copy or print.
[Description]
[Solution]
Engineering specifications allow for up to 15 mm of possible unacceptable density on the second side lead and trail edges of an 11x17 inch copy or print. The extent of image loss will depend on paper type, weight, and moisture content. To minimize image loss, the following should be checked and set to specification as outlined in the service manual:
1. Run 11x17 1:2 sky shot (black copy) and copies of test charts for reference.
2. Enter the 36 mode and select Image adjustment.
3. Select #2 (magnification adjustment).
4. Perform Printer drum clock adjustment 1:1 mode and 1:2 mode.
5. Perform printer horizontal adjustment 1:1 mode and 1:2 mode.
6. Perform scanner drum clock 1:1 mode and 1:2 mode.
7. From the image adjustment screen select #3 (Timing adjustments).
8. Perform printer restart adjustment 1:1 mode and 1:2 mode.
9. Perform printer lead edge timing adjustment 1:1 and 1:2 mode.
10. Perform scanner restart adjustment 1:1 and 1:2 mode.
Note: When performing these adjustments, when in 1:2 mode, only the second side is adjusted.
sunsetoutpost
01-02-2013, 09:27 PM
OK, sorry it took mo so long to post this. The problem was in the solutions book, replaced conveyance rollers 2 & 3. Life is good. Thanks everyone.
