View Full Version : Miscellaneous Bizhub 501 bootup screen
tmathiou
12-19-2012, 12:12 PM
Hi All,
Can anyonehelp me out?
we got one OceVarioLink 5022 machine ( Konica Minolta Bizhub 501), in this machinethe bootup screen is different from bizhub series (only planets).
I upgradedto the latest firmware version but nothing change in bootup screen logo
How can I change in to Konica-Minolta boot upscreen logo ?
Thanks in advance
ineo+6501
12-19-2012, 12:26 PM
Why would you want to If it's an Oce machine?
tmathiou
12-19-2012, 12:51 PM
Oce VarioLink 5022 is actualy a Konica Minolta bizhub 501.
We have the Konica Minolta Pagescope Enterprice Suite but unfortunately does not working with Variolink.
ineo+6501
12-19-2012, 03:43 PM
Fair enough. You need to enter service mode, system 2, dip SW, change the correct switch to show the OEM screen and print engine in the config page.
tmathiou
12-20-2012, 08:04 AM
Ok i understand that.
The problem is that the service manual does not mention dipSW for the OEM screen.
methogod
12-20-2012, 10:07 AM
I use Variolink toner on my KM all the time, they key the toner differnt - its easy to convert.
To change the Configuration Page header to Konica Minolta bizhub, please perform the following:
1. Access the Service Mode.
2. Select System 2.
3. Select Software Switch Setting.
4. Enter Switch No. "10".
5. Bin Assignment "00000000".
6. Hex Assignment "02".
7. Click on Fix.
8. Click on End.
9. Power the MFP OFF/ON.
10. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
tmathiou
12-20-2012, 10:30 AM
This procedure is for color machines. Μust be a corresponding process for black and white machines.
methogod
12-20-2012, 11:02 AM
came from solutions with 501 in info... Check dip switch, check, reset, if no change put back...
here it is....
Products
Products:
bizhub C450P
bizhub C450
bizhub C252P
bizhub C252
bizhub C250P
bizhub C250
bizhub C352P
bizhub C650
bizhub C550
bizhub C451
bizhub C353P
bizhub C353
bizhub C253
bizhub C203
bizhub C360
bizhub C280
bizhub C220
bizhub C652
bizhub C652DS
bizhub C552
bizhub C552DS
bizhub C452
bizhub 751
bizhub 601
bizhub 501
bizhub 421
bizhub 361
bizhub 423
bizhub 363
bizhub 283
bizhub 223
bizhub 652
bizhub 552
bizhub C754
bizhub C654
bizhub C351
bizhub C352
bizhub C300 Options:
None Specified
Details
Subject:
No Konica Minolta logo at power up ("Planets" only), Configuration Page header is printing as Generic and printer driver fails when trying to acquire the device information.
tmathiou
12-20-2012, 11:29 AM
This is Solution ID:TAUS0701329EN*. I've tried without success. Do you have any other suggestions?
ineo+6501
12-20-2012, 03:28 PM
I've noticed within system 2 on the 501 a button called "OEM" which has a on or off setting. Don't know what that does as there is no description in the manual.
tmathiou
12-20-2012, 03:46 PM
The problem is that in our particular machine does not exist oem button. Must be a dipsw to enable, but do not know which.
tmathiou
12-21-2012, 03:45 PM
any ideas? somebody?
methogod
12-21-2012, 05:03 PM
This is right just tried it on a OCE version.
2. Select System 2.
7. Click on Fix. <--- make sure you press this if you press end it wont take....
8. Click on End.
9. Power the MFP OFF/ON. <--- make sure you wait 20 seconds - and turn off both sub and main power
tmathiou
12-21-2012, 08:58 PM
As I said earlier, this should be only for color machines. However i have tried. bizhub 501 default setting of dipsw 10. Bin Assignment "01000110" and not "00000000". Hex Assignment "46" and not "00". "Fix" buuton is "Set" button. "End" button" is "Exit" button. However i have tried Hex Assignment "02". Set instead of Fix. Exit instead of End. Power the MFP OFF/ON. But nothing. I wish to inform that I have done this process in a color machine, and it worked fine. Obviously we need another dipsw. Thanks.
tmathiou
12-22-2012, 08:01 AM
Solution ID TAUS0701329EN* Solution Usage 21
Description
No Konica Minolta logo at power up ("Planets" only), Configuration Page header is printing as Generic andp rinter driverfails when trying to acquire the device
information.
Solution
CAUSE: Incorrect settings.
SOLUTION: To change the Configuration Page header to Konica Minolta bizhub, please perform the following:
1.Access the Service Mode.
2. Select System 2.
7. Click on Fix.
8. Click on End.
9.Power theMFP OFF/ON.
10. Print another Configuration Page.Page Header should now be changed to Konica Minolta.
Note :Header Information:
Generic 20C-4= C203
Generic 22C-1 = C220
Generic 25C-1 = C250
Generic 25C-4= C253
Generic 28C-1 = C280
Generic 35C-3= C352
Generic 35C-4= C353
Generic 36C-1 = C360
Generic 35C-1= C450
Generic 45C-2= C451
Generic 45C-1= C550
Generic 50C-1= C650
To change the Configuration Page header to Konica Minolta bizhub (for Printer-only models), perform the following:
1. Press the Menu/Select key.
2. Press the down arrow key 4 times to select “Tech. Rep. Mode”.
3. Press the right arrow key. Enter the Tech. Rep. Mode password 9, 2, 7, 2, 9, 2, 7, 2.
4. Press the Menu/Select key.
5. Press the down arrow key 16 times. “Software SW” will appear.
6. Press the right arrow key. “Switch No.” and “1” will appear.
7. Press the Menu/Select key. “1” will start blinking.
8. Press the up key and change this number to “10”. When pressing “Menu/Select” key, the above settings will be saved and the display will show “Bin
Assignment” and “00000000”.
9. Press the down arrow key and the display will change to “HEX Assignment” and “00”. Then press the down Menu/Select key. The “00” will blink.
10. Press the right arrow key and the 1st digit will blink. Change setting to “02”.
11. Press the Menu/Select key to fix the value. The display will change to “Software SW”.
12. Cycle the main power switch OFF/ON.
Generic 25C-1P= C250P
Generic 35C-1P= C450P
Generic 35C-3P= C352P
Generic 35C-4P= C353P
Please see the attachment for the visual symptom. To viewthe PDF, Adobe Reader® must be installed. Adobe Reader® can be downloaded for free from the
Adobe® web site at: Adobe - Adobe Reader download - All versions (http://www.adobe.com/products/acrobat/readstep2.html) .
SPECIAL NOTE : Solution contribution by Jim Behrends, Worgroup/SSD and Greg Lantowski/Ian Lynch/Mark D'Attilio/Cesar Jimenez, Production Print/SSD,
SPECIAL NOTE: Solution contribution by Dave Bruni, Workgroup/SSD
As can you see ONLY COLOR
methogod
12-22-2012, 10:53 AM
Cant help you then, but i just tested this solution on a Konica 601, worked fine - turned off the globe, then put it back to KM standard.
Only think i can think of is the OCE firmware is customized or something. Not very familiar.
May i ask why you need to make it back to a konica, unless you change the toner hopper it will still take oce toner.
tmathiou
12-23-2012, 03:22 PM
tmathiou
12-23-2012, 03:33 PM
From Oce System 2 settings "OEM ON/OFF" button is missing.
tmathiou
12-23-2012, 07:29 PM
This is Oce System 2 settings
methogod
12-23-2012, 11:56 PM
Ok so check out your firmware, does it match the lastest KONICA firmware?
i would do a print out of your dip switches.
I have gotten a 920 before that has some weird shit, did a side by side comparison with a current machine, found they had switches on that had no setting anywhere.
Locking options and other screens.
One of the software switches turns that off and on, pretty sure of that.
tmathiou
12-24-2012, 09:58 AM
We have installed the latest konica minolta firmware. The question is which one dipsw.
methogod
12-24-2012, 02:05 PM
Print out the list with shows all settings, it will list all dip switch settings.
then have someone on the board do the same for a konica version, compare.
should only be a few that are different - look up those, in konica manual - eliminate until you find the switch that turns OEM ON/OFF back on.
Not that complicated - you seems to really want to do this, so this is what you need to do.
if you can get me the lists ill take shot at it, done it before.
tmathiou
12-24-2012, 03:43 PM
We changed all dipsw to default with service manual but no luck.
methogod
12-24-2012, 05:36 PM
its not going to be a listed in SM.
Go into Service Mode. Print out dipsw that will be in the manual, print a management list (complete).
then scan it to the board.
methogod
12-24-2012, 05:55 PM
I know know as much about the newer mid volume B&W machines, but on the older B&W productions variants i know its management list, i just tried it on a C650 and it did not give me the dipsw settings, may have to look into it further.
do you have a konica 501 in the field you can have someone go line by line with on?
may not figure out which switches it is, but will get it back to KM stock.
tmathiou
12-27-2012, 07:34 AM
This is the dipSW table.
methogod
12-27-2012, 09:37 AM
Post directions how to print this list, so someone with a 501 can print this for you...
my only note is that compared to a color machine your DipSW 10
should be 00000110 HEX 06
try that..
cant hurt maybe there are more then one KONICA setting, one that sets, one that protect's/hides for 3rd parties.
I am sure OCE has gotten tired of tech converting re-selling their machines.
