View Full Version : Konica Bizhub 361 FTP printing
markham89
12-20-2012, 03:17 PM
Hi,
Does any one know what the Login and Password for the FTP server on a Konica Minolta Bizhub 361 ?
I can do it on HP and Xerox with anonymous login with no problem, but konica bizhub 361 seems ask specific ftp account , anyone have this info?
thanks a lot
ni311
12-20-2012, 05:40 PM
Write in the browser address the IP of the machine and go to the admin page. There you should be able to find the details you need.
markham89
12-20-2012, 06:05 PM
I have already access to admin page, and i have activate ftp server function but no notice about ftp printing and ftp login and password.
ni311
12-20-2012, 07:10 PM
Once I'll get next to machine I will check it, most probably tomorrow. Hold on :)
markham89
12-22-2012, 04:17 PM
any idea ?
markham89
12-26-2012, 06:48 PM
up up up
emujo
12-26-2012, 07:02 PM
Are you sure you don't mean FTP "Scanning"...If so then you need to put the CD in the worksation drive and let it do it's magic...Sets up the services on the client side and creates an folder that can be accessed anon...EMujo
markham89
12-26-2012, 07:52 PM
no,
it's ftp printing,
in most of network postscript copier, you can log in using an ftp client software and put a postcriptfiles directly on copier,
i want do that with my konica, but ftp access seems requiers passwords
ftp printing on my konica bizhub 361 seems possible, or not ? that is the question.
thx a lot
emujo
12-27-2012, 01:23 AM
Sounds likes something that may be possible on a KM product with a Fiery attached as this will run true PS, something like a hot folder, but the only settings under admin for FTP deal with scanning (port 21). Is this an older technology like TWAIN or IP scanning that is rarely used anymore???EMujo
JR2ALTA
12-27-2012, 01:45 AM
I have done ftp data capture through command prompt,
that was login : capture
password : sysadm
probably absolutely no help
dallas
12-27-2012, 12:04 PM
FTP printing is not available.
EarthKmTech
12-27-2012, 02:22 PM
(in windows) use the lpr command and send the postscipt file straight to the machines IP address if non conventional printing methods arent an option. Direct print using the machines web interface may provide what you desire too.
If you have some strange application that requires ftp printing, i think you may well be out of luck.
