View Full Version : KM machines automatically emailing meter readings
Solotime
12-20-2012, 04:01 PM
I have been tasked with the job of trying to set up some machines in the field to email meter readings. I can not locate the menu settings on a few so thought I would ask if they had the capability. The models I need are the C250 and BH250. Do either of these models have the capability to email meters and if so where are the settings located? Note: These are only on machines that are already setup to scan to email so that part of the setup is done.
ni311
12-20-2012, 05:36 PM
On the color machine I'm sure you can, I already done that. The problem is that you won't get very detailed counters, like separate color and b/w prints. From what I am remembering, you will just get totals, copies, prints and scans. The b/w machine should be able to send these counters, too.
Let me know if you need the exact menu, I'll take a look at a machine tomorrow.
avecosat
12-20-2012, 06:01 PM
The BH-250 is not possible but the C-250 you can do it . In Administrator settings , network setting , detail setting , total counter report setting . YOu need all scan to email setting : SMTP adress , email direction , administrator direction , etc.... good luck.
Solotime
12-20-2012, 06:58 PM
Thanks Guys,
The trouble I am having specifically on the C250's is that there is no total count report setting when entering the Admin Mode via the operation panel. Even tho I can see it via the web browser on SOME machines. I have 2 that I am trying to setup that have no total counter report settings even under the Admin Mode of the Web Interface? Wondering wether it might be only on a certain firmware level? Maybe earlier ones did not have this feature?
ni311
12-20-2012, 07:18 PM
Maybe is just a firmware issue. Be sure to upgrade all the machines to the same firmware version.
Solotime
01-30-2013, 09:25 PM
I did find out it is a firmware add. When I run into this now I just upgrade the firmware!
EarthKmTech
01-30-2013, 09:56 PM
that must of been very old firmware.
one easy way to check how ancient the firmware is on the c250/252/351/450 series is, is try to print the meter count page - if it lacks the option to print it double sided you are running ancient phase 1 firmware. There is a risk of loosing the entire address book data if you update from a version this old and you will always need to version up the hard drive regardless when updating from a previous phase. (you'll know about it because you will get an error code on reboot)
kronical
02-13-2013, 11:24 PM
Thanks Guys,
You can only set this up via web browser, you may need to update to newer firmware for this feature to be available.
