printing blackand white
  • stedros
    • Oct 2011
    • 34
    l have a printer C253 konika minolta bizhub some times it printes black and white yet i have comamanded it to print colour
    l triedto change to the up to date printer drivers but it failled, l also tried to change the Pc (Computer) but still the same thing
    this problem happens some times but it is now coming frequently , some times it printers in colour , some times in black and white
    some help pliz if possible
  • Copierconsultant
    Re: printing blackand white
    are you printing from a windows computer or MAC?
    • stedros
      • Oct 2011
      • 34
      the computer has windows 7 pliz some help if any one has a solution
      • stedros
        • Oct 2011
        • 34
        i tried on diffrent computers of windows 7 and wndows XP but it is the same thing
        some help
        • stedros
          • Oct 2011
          • 34
          some help pliz if possible the computer is windows 7 and windows xp but Mac
          • 1FRY1
            • 51
            Is this a Driver issue or a machine issue
            Does it do it when copying or just printing
            I have had this and it was the colour first transfer rollers not engaging properly (sensor engaged so no error code)
            • Darren King
              copiertech
              • 652
              What program are you printing from?
              • Chameleon
                • Nov 2011
                • 200
                This is an issue with the document you are printing. There is a priority for the settings.
                3. Machine
                2. Driver
                1. Application/program
                In other words, the (3) Machine settings get trumped by the driver settings, and the (2) driver settings get trumped by the (1) application settings. You eliminated the C253 when you commanded it in the driver to print color. You eliminated the driver when you printed the document from XP and Win 7. The only thing left is the application/program settings. Whatever program your document is printing from is setup to print B/W, that is the only thing that trumps the driver. What program are you printing from? Check the page setup in MS-Office, if Adobe check advanced>print production>preflight.
                Can you explain updating the driver failed? That sounds like a corrupt print driver. Have you deleted the print driver an reinstalled it? Especially with color, add the driver through the "Add a Printer" wizard, never through the "New Driver" button. Hope this helps.
                The chance that higher life forms might have emerged in this way is comparable to the chance that a tornado sweeping through a junkyard might assemble a Boeing 747 from the materials therein. -Fred Hoyle
