View Full Version : Problem in Konica 7030
Dinos
01-17-2008, 06:58 AM
The message is :
Please insert key counter
I can not turn it of from dip switches
dogsbody
01-17-2008, 07:38 AM
There is a link that has been removed from the machine to connect a coinbox/cardreader or some other device. Whoever removed the device didn't replace the link plug. Call your local dealer and they should be able to supply and or fit it for you.
Cheers
CMB
01-17-2008, 11:25 AM
its called a jumper. be sure to use the right one. plug in the wrong one and you will blow the main control board.
Dinos
01-18-2008, 06:25 AM
Thank you very match, it was just a bad connection of that jumper.
bsiap
02-09-2008, 11:15 AM
Patrioti evgales akri?:)
Dinos
02-10-2008, 01:02 PM
Ναι τελικά δούλεψε το παλιόπραμα.:confused:
