Can not setup Paper Type Konica C6500
  • truongson
    • May 2011
    • 67
    Hi all,
    My Konica C6500 hide all the Coated-GL, Coated-ML, Coated-GO, Coated-MO ,
    When I go to Paper Setting -> ByPass-> Change-> Paper Type-> Color Specific all item Coated-GL, Coated-ML, Coated-GO, Coated-MO are hide, so I can not choice the Paper I want to print ? How is it ?
    Thank you,
  • JustManuals
    • Jan 2006
    • 9838
    Re: Can not setup Paper Type Konica C6500
    Paul@justmanuals.com
    • methogod
      • Dec 2008
      • 915
      when you set the paper type you need to match it on your fiery / or the fiery print driver.
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        Sounds like someone delete the paper catalog and you will need to recreate it.
        • truongson
          • May 2011
          • 67
          so how can i recreate the paper catalog ?
          • Mr Spock
            • Aug 2006
            • 2064
            For English go to the following website and then select the "production print" in the first column, c6500 in second column and user guides in the last column.
            Download the manuals and it will step you through it.
            Support | Konica Minolta Business Solutions, U.S.A., Inc.
            • methogod
              • Dec 2008
              • 915
              before clearing your paper, make sure you are setting the trays before each job to match the name of the paper, unless you are just matching specs.
              Which fiery or creo?
              C6500 or C6501?
              quick fix if your missing paper catalog is to go to server (in command workstation), "backup & restore" , then restore the paper catalog.
              • truongson
                • May 2011
                • 67
                C6500 or C6501?
                I'm using Fỉey and machine C6500 , I will try to fix .
                Thank you,
                • methogod
                  • Dec 2008
                  • 915
                  IS THE FIERY LOOK LIKE A SILVER PC OR JUST ON THE BACK OF THE COPIER?
                  msg me on skype i can help more.
                  • truongson
                    • May 2011
                    • 67
                    Fiery on the back of the copier, I will install skype then.
                    • methogod
                      • Dec 2008
                      • 915
                      if its on the back you have to use a computer anyway to access via command workstation.
                      • truongson
                        • May 2011
                        • 67
                        yes, I access to Backup and Restore, When i click to Restore it go to "Select Items To Restore" I don't know how to Restore with 2 choices : From specific location or From a recent backup .
                        • methogod
                          • Dec 2008
                          • 915
                          wrong place for internal fiery..
                          Click on tab at top call DEVICE CENTER
                          then RESOURCES
                          THEN PAPER CATALOG
                          If you machine is a sleep wake it wait until it "see's it", you should see the paper names you have in the trays, you just need to assign them.
                          if you think its a glitch you can reset on fiery, its near top "reset to factory".
                          Paper Tables are 1 way,,,,
                          C6500 can READ & WRITE to FIERY
                          Fiery can ONLY read and send paper confirm's to Konica (wont set it from fiery).
                          Email me i can fix this via remote support..
                          m-scudder@comcast.net
                          also visit teamviewer and install there software, so i can do this quickly.
                          • truongson
                            • May 2011
                            • 67
                            then RESOURCES
                            THEN PAPER CATALOG
                            ohh, My Copier doesn't work now, I don't know why when I turn on the power and the machine doesn't warming up and the LCD screen darkness with no any thing appear .
