View Full Version : Dead FD-501 folding unit
Splatt
01-04-2013, 02:55 PM
Hi All,
I'm hoping someone can offer a bit of help with a dead FD501.
When the unit was connected to the system for the first time I powered up and a breaker tripped on the consumer unit. After resetting and powering up the FD appeared dead.
I have removed the rear panel and notice a flashing amber LED on the topmost circuit board. There are two breakers/relays on the bottom left of the unit that appear to be letting power through, pressing the external buttons doesn't seem to affect the circuit.
I have looked for a fuse near the transformer but I can't seem to find one.
I presume that the IC's are fed from a separate power supply and that's why I am seeing power to the board.
If anybody can shed any light on the most likely cause I would be most grateful.
Also, if there are any techs here on the Costa Blanca in Spain I would happily pay for someone to come and look at it.
Thanks in advance for any advice.
Steve.
Mick01
01-07-2013, 04:59 AM
Most likely your issue is a blown power supply in the FD unit. The FD control board is supplied 5vdc from the main body to run the logic circuit.
Hope this helps.
