Konica C452 Address Books
  • percx
    • May 2025
    [Misc] Konica C452 Address Books
    Is there any way to convert the binary output of the Address Book export to a delimited text file for import into another brand.
    Or a method to export it directly to a delimited text file
  • morpk
    • Oct 2010
    • 97
    Re: Konica C452 Address Books
    this wont work with all versions of machine e.g c452 - C284
    • first export the address book (i think the one you downloaded was the read only)
    • once you have downloaded it should look like C452_addresses.txt
    • change the name to c280_addresses.txt (assuming that the machine is a c280)
    • then open the .txt file and find the line that says @v31 C452 (and change this to C280) save all changes.
    then import that to the machine, keep in mind this wont work for all versions because the formatting can be different.
    hope this helps
