View Full Version : Error Code C2558 error in Bizhub 164
amethyst30
01-16-2013, 05:42 AM
I have a problem on the error C2558 in Bizhub 164. I have changed the tcr sensor and OPC drum, still, after warming C2558 immediately appeared. I have closed and open the front door but C2558 kept on appearing. Do I have to change the developer powder?
Thank you for any idea you may share with me.
Sincerely,
Amethyst30
humpty dumpty
01-20-2013, 07:16 PM
You have to replace the dev and then run dev setup otherwise you will keep getting this code.
cheers
Sincerely,
Amethyst30
i will first replace developer and do atdc adjustment (tcr)
amethyst30
11-20-2014, 08:13 AM
cheers
Thank you for the reply. I followed your method and it worked well. As of now I am still using my bizhub 164.
Amethyst30
