View Full Version : how to eliminate reduction in booklet mode on C550
SAR
01-18-2013, 04:30 PM
Trying to do booklet mode copies through the df on the copier. 8 1/2 x11 originals copied onto 8 1/2 x11R paper. The copier auto selects 64.7% reduction ratio, which is correct. This particular customer wants their copy to not be shrunk (the print on their originals is small enough that it would fit on 5 1/2 x 8 1/2 page, but when it gets reduced 64% it is too small for them). They swear their old copier would do this, but of course ours won't.
If you try to just set zoom to full size with booklet, it will shift the image off the page. Also, you cannot use centering with the booklet function.
emujo
01-21-2013, 02:41 PM
Tried this on a C652...8x11 in ADF, centerfold/staple, 8x11R as paper source..As you stated auto reduced to 64%.. Manually set zoom to 70% and it worked fine..my orignals were full size and it did make them go off the page just a tad, but other that that it was OK. Emujo
SAR
01-22-2013, 03:12 AM
Thanks for the reply. I'll give that a try.
