View Full Version : Dead Machine konica minolta bh211 Machine powers on then cuts out!!
humpty dumpty
01-20-2013, 07:09 PM
I have a problem on a bh 211, The machine powers on then cuts out straight away, i have changed the fuser and interlock switch. any ideas guys!!!
thanks in advance
humpty dumpty
01-21-2013, 08:19 PM
My good old diamond geezer suggested it may be DCPS so have ordered it!!!
will let you know outcome but i recon it may be this as he is an old fossil!
JustManuals
01-22-2013, 06:47 PM
Paul@justmanuals.com
humpty dumpty
01-22-2013, 08:46 PM
I don't need a manual!!
Hansoon
01-23-2013, 06:47 AM
WTF is DCPS?? Something like PMS or CRS?
Hans
does it turn off immediately after switching on?if no,check the auto shut off time.if yes,first i will go for fuse(but u changed it) then i will check for a short in hv.try to check also the flatcable of the scanner were it twists,maybe there is a thorn and makes short,and also check for a nibbled wire from a rodent(mouse),once i had this problem and found a wire scratched by mouse which was shorting!
EarthKmTech
01-23-2013, 10:18 AM
stupid question, but does it shut off instantly with the side door open too?
EarthKmTech
01-23-2013, 10:19 AM
Hans
sounds like canon talk to me, for DC power supply
mick o connor
01-23-2013, 08:42 PM
hi, something to check, is there a PF 502 fitted????, In the distant past I had a customer move a similar machine to a new office, lifted m/c off cabinet, pulled the wiring loom ,
when they reset the machine on the paper unit the broken loom shorted of the metal. lets know how you get on, thanks Mick
humpty dumpty
01-23-2013, 09:58 PM
Thanks for all replies I am hoping to visit this mc tomorrow weather permitting! Will let you know my findings cheers!
humpty dumpty
01-24-2013, 12:18 PM
[QUOTE=EarthKmTech;336325]stupid question, but does it shut off instantly with the side door open too?[/QUOTE
the machine powers of only when you shut right hand door or front door !!!]
EarthKmTech
01-25-2013, 11:15 PM
then yep, it sounds like a fusing malfunction, although I think there are a few other critical errors that will cause the machine to automatically switch off (this in itself is not a fault, they are supposed to do that when a high level critical error is detected) Consult the service manual.
Usually there is an error code displayed for at least 1 second before the automatic shut off.
mrwho
01-26-2013, 01:11 AM
Turn the machine on while pressing the stop key.
humpty dumpty
01-26-2013, 07:43 AM
Ok I have been to machine, changed Dc power supply, fuser, rear door interlock switch, I have turned on machine whilst holding stop, the pf wireing was caught but not the issue as unplugged PF completely.
I have now ordered front interlock for rhs door and interlock switch for front door and also main on/off button switch and Loom.
Any other suggestions guys and gals?
EarthKmTech
01-26-2013, 01:31 PM
What is the code that flashes on the LCD prior to it turning off ?
RRodgers
01-26-2013, 03:02 PM
Do you have a surge protector on it?
If you take off the cover where the paper exits on and look right at the back you will find a small board with a relay on, try that if all else fails. BTW, i am referring to a B210, but i am sure it hasnt changed.
mrwho
01-29-2013, 10:31 PM
I'm here sitting and thinking if this isn't just a fuser problem, with the machine firing up the code even after it is released...
