View Full Version : Minolta 2010 cs pro Jamming @ Drum Unit
sagar4
01-21-2013, 09:02 PM
I have a minolta 2010 CS Pro jamming on and off at the drum. Seems like static when it sticks to the drum. I can pull the paper right off. It seems like it clings to the drum. I was thinking about replacing the conrona assembly since the one on the copier looks worn out. Every thing else looks fine. Any suggestions. Thanks
Darren King
01-21-2013, 09:14 PM
Possibly the registration clutch is failing. Clean or replace.
Darren
mo0651
01-22-2013, 02:12 PM
IS THE SEPARATION WIRE IN THE UNIT BROKEN? Is the paper folded and jammed or just laying in there?
sagar4
01-22-2013, 05:07 PM
Wire is not broken. And yes it folds slightly and sticks to drum. Not all the time maybe evey 20th sheet or so. That's why I was thinking the corona assembly not functioning correctly and static builds static up.
mo0651
01-22-2013, 05:13 PM
Nope sounds like clutch.
sagar4
01-22-2013, 05:24 PM
Okay clutch it is. By any chance would you know the part number. Thanks
Hansoon
01-22-2013, 06:22 PM
No need for new. Soak it and wash it out with brake cleaner than blow dry with compressed air. Works like new for sure.
Hans
sagar4
01-22-2013, 06:40 PM
Okay thanks every one for the information.
johnnymeg
01-24-2013, 03:57 PM
If that does not work try the solenoid for the drum pick off. It has been awhile but I remember that causing a similar issue.
