This is now the 2nd time in 40K that i have seen this. The first time manually flipped the blade. PM, DV, Drum all are around 250K maybe slightly more. Every now and again you get this when a blade is bad or its a old blade.
I will replace it once more, to see if its just happened to be an old pm kit. But any suggestions. Any one ever increase the pressure the blade makes on the drum? is there even an adjustment?
I consider myself a 920/950 specialist, but this is puzzling, because as i have said never seen it happen so fast on 2 blades in a row. Cleaner unit has about 5.5M on it as does dv unit. Runs like a champ other then this...
thanks,
thanks,
