View Full Version : Electrical bizhub c252 transfer belt fuse
sn00kerpaypal
01-28-2013, 01:59 PM
Can anyone help with changing the above and tell me size and rating the fuse is
Regards
Imsdal
01-28-2013, 02:28 PM
80 mA.
juve
01-28-2013, 04:48 PM
can anyone help with changing the above and tell me size and rating the fuse is
regards
80ma fuse.on the side you have to remove a small screw and an e clamp ,remove cover(also there is a spring)put the fuse and re assamble.
JR2ALTA
01-28-2013, 06:48 PM
yea what the hell is that "spring" for?
minimerlin
01-28-2013, 07:16 PM
yea what the hell is that "spring" for?It`s just there to be a pain in the a**! I think it is supposed to be an earth connector but if it is missing I never bother about it and no problems occur.
juve
01-28-2013, 07:54 PM
infact i also remove that stupid claw in the middle,better without it,when a big paperjam happen this f##ken claw turn around and damage the belt,so better without it,
Avskrap
01-29-2013, 03:55 PM
If the claw is missing or busted, you'll get a bunch of papers stuck in the cleaning unit for the transfer belt.
I've seen this happen quite alot, this friday I cleared out five papers stuck in the CL unit on a C353.
I usually loosen the screws for the holder and flick in back in to place if the customer doesn't notice the "mustache". If they do, new belt.
juve
01-29-2013, 04:44 PM
in my case,even with the claw there,if the paper used is humid the paper will jam and go underneath the claw
ronanl
04-05-2013, 04:32 PM
hi where will I find the fuse on the transfer belt?
kingarthur
04-05-2013, 04:59 PM
In the fuse holder?....
ronanl
04-05-2013, 05:51 PM
thanks for that I have found it, would you know if it is possiable to reset the black fuser as it is at 20% even thought the machine has been used for less than 20k copies. thanks again for your help
rrrohan
04-06-2013, 12:22 PM
i have always wondered about that.
i was finding on the low volume machines that claw alwyas leaves a dent.
So you have removed it without paper curling back into belt?
Might start doing this
juve
04-07-2013, 12:55 PM
yes it worked.obviously i found that if the paper is too damp,with or without it,it will still enter in belt,so better without it.and if a paperjam like this happen there will be no damages because of this claw,just remove the papers from belt
