View Full Version : Help!! Right Gasoline Generator capacity for 2 Copiers
akuamariane
02-01-2013, 12:03 PM
please i need some Technical advice with calculating the right medium size Gasoline generator to adequately power the following equipments in a small print shop.
2 photocopiers (canon IR 4570 and IRC 3220)
HP laserjet 4250
2 desktop computers and a laptop.
please help me calculate the wattage
Thank you
blackcat4866
02-01-2013, 05:09 PM
What is the wattage draw from each of these items? In the US there is a metal tag by the power cord stating the draw either in amperes or watts, either is fine. If it's amperes: P=IV or watts = amperes x voltage
Convert all your units to watts and add up the sum. Then buy a gasoline generator capable of supporting this maximum load.
There are variable here I won't know:
What voltage is used where you're at?
What wattage draw per item? That differs based on voltage.
I certainly hope you're not going to network these devices. Most gasoline generators do not provide a steady enough power source, even when within the proper load capacity.
akuamariane
02-02-2013, 03:33 PM
thanks man! i got all the info i needed. :)
