Bizhub C6500 Vertical lines, not consistent colors.
  • suso73os
    • 38
  • JustManuals
    • Jan 2006
    • 9838
    Re: Bizhub C6500 Vertical lines, not consistent colors.
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • Mick01
      • Nov 2012
      • 362
      A bit more info on the scanned image would be helpful in isolating the issue. I can see the lines but am uncertain of the direction of the lines. Are they in the feed direction or the cross direction?
      Looks like someting blocking the laser path to me.
      • methogod
        • Dec 2008
        • 921
        test mode..
        run test 1
        180 of 255
        set C and M to 180 to make a (GREEN) test
        then clear them back to zero (black should be zero)
        then set Y and M to 180 to make a (ORANGE) test
        scan them at 600 dpi, so we can see WTF is going
        that should tell us alot more..
        looks like drums are failing, i get that bluish stripe when you try and do partial PM KITS. i have learned you have to do it all. no point saving 100 bucks, when it will cost you a lot more in time later.
        also looks like very thin paper, what stock are you/your clients using? lighter then 50#? be careful, takes a magician to run that think with normal stock before you start running onion skin...
