KM C451 Panel Problem
  • mindhunter
    • May 2008
    • 102
    hi everybody
    My Copier Print and Scan fine . and my touch panel works too. I can select anything on touch panel menus. but my panels button doesnt work(Exept power button and contrast volume).
    I try to do trouble reset too. but when i hold utility button and power on the copier nothing happens and copier doesnt go to the trouble reset page and copier start normally.
    Any suggestion that what I have to do ?
  • mrwho
    Major Asshole!
    • 4297
    Re: KM C451 Panel Problem
    First step is to dismantle the panel and check all the connections.
    Mascan42
    Ibid
    • JSC
      Gimp
      • Dec 2006
      • 618
      Or check for a button stuck down.
      The gene pool could use a little chlorine.
      • mindhunter
        • May 2008
        • 102
        NO im sure the button is not stuck down . I press all of them one bye one . and as you know if a button suck down we must hear at least one beep for it . right?
        • mindhunter
          • May 2008
          • 102
          I checked them.everythings fine. and we have connection when I touck the screen . but I dont have in buttons
          • mindhunter
            • May 2008
            • 102
            the problem is for panel. I have changed panel and new panel work easily.
            do you have any proffesional Idea?
            could I repair the damaged one ?
            thannks buddy.
            • wildx
              • Jul 2011
              • 10
              I have had a similar problem with bhC451 where touch panel and keypad buttons were all unresponsive. I have found after quite a bit of swap testing that the RAM cards where faulty. Changed them and all is good again! Hope this is of some help!
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2141
                no parts are available inside the panel. if its defective it should be replaced as a whole.
                If you feel like opening it up and troubleshooting the board, that's your business but it not recommended nor suggested by konica minolta.
