BH 601 toner supply assembly
  • acsolutions
    • Jun 2010
    • 519
    [Misc] BH 601 toner supply assembly
    hello, the 601 I'm working on is not rotating toner bottle so I swapped it with a 600 unit. Now its rotating the bottle but the door does not shut properly, the door shuts and stays closed but not as easy as the original one. my question is, what's the different between the BH601 and the BH600 toner drive units? I'm hoping that the customer will be ok with the way it is, but just in case I kept the original unit. Thanks
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    Re: BH 601 toner supply assembly
    If it is working now did you consider just swapping the motor and reinstating the original tray?
    • acsolutions
      • Jun 2010
      • 519
      yes I did!
