copy shop
01-24-2008, 02:43 AM
My problem from below was:
I did not have the toner bottle door all the way closed.
__________________________________
My system says Please set toner adding unit correctly. I opened the machine toner FRONT door where you put the toner in and closed it and after trying to warm up, it showed a code sc45-01, and I turned it off and back on and it still just says Please set toner adding unit correctly. Is the toner adding unit in the drum section that pulls out or in the door where the toner bottles go? A service manual with the solution errors codes would be nice.
Thank you
Tammy
Thank you
Tammy
