View Full Version : Biz hub c350 c0510 code reset
blazebusiness
02-12-2013, 07:32 PM
Have seen a lot of posts in this forum asking how to reset fuser code on the biz hub c350. Here is a pic of the microswitch location inside front door you need to push to reset those codes. To the right of the k drum unit there is a cutout....the micro switch is inside the opening. Hope this helps someone in the future. There are a lot of erroneous posts telling people to cycle power while holding down the utility key. That info is for the biz hub c351 and c451.
EarthKmTech
02-12-2013, 09:44 PM
Its a carryover from the CF2002 series as its there too.
gyrfalcon
09-09-2013, 05:14 PM
I though you guys might have been pulling a joke, but after a few minutes on the floor with a flashlight I found the elusive micro-switch. It's almost like the designer used to install drug stash box release switches in courier vehicles. :rolleyes:
http://i.imgur.com/yzLTpCvl.jpg
Thanks again!
blazebusiness
09-09-2013, 06:03 PM
Thanks again!
Welcome---Glad that the info helped you.
OLADINEO
02-27-2017, 02:03 AM
Thank you Blazebusiness for the info on the Code Reset. I worked for me perfectly although I had to remove the cover at the location shown in the pic by Blazebusiness before I could see the reset botton.
thanks.
