AB1984
02-19-2013, 10:18 AM
Is it possible to make the caching of PS and PDF object a default in Command Workstation 5 running a C8000?
Caching objects speeds a lot of our jobs up (we like to print face up normal order, which means the whole job has to process before it runs off).
I'm not sure if this is a driver issue or what.
Also, as a side note, we have a c5501 running through the same Command Workstation...is the 'Use PDF Xobjects' the same as caching (as in it it would speed up the processing of jobs with the same graphic repeated), or is this an older version?
Cheers
Cheers
