View Full Version : fs-4000dn error codes
comdoctor
01-25-2008, 02:17 PM
Good morning,
I have a client with an fs-4000 dn that was plugged into the wall and on when a circuit breaker popped in the room . After resetting the circuit breaker in the electrical panel the printer has CALL SERVICE
7410:0026245 showing in the led panel. I have searched the net to no avail trying to find this code, or a link to a service manual.
Anyone seen this one?
Thanks in advance.
comdoctor
techman
01-28-2008, 09:57 PM
the error is for the drum not being set in place remove the process unit and open the left side cover where the drum is located. Remove the toner waste bottle and make sure the drum is pushed in all the way if it is you may need to replace the drum.
comdoctor
01-28-2008, 10:03 PM
I did manage to d/l a manual and got the error codes. I removed the drum from that printer and popped into another same model, the unit power up fine. I put the drum back into the the 1st printer and it also power up fine. Just needed to have the drum re-seated i guess. Thanks for the tips and all of the good advice here.
wild_guest
04-17-2008, 11:51 AM
Hi
Can you please help me with this error code
7410:0190114
blackcat4866
04-17-2008, 06:04 PM
This is extremely common when anything out of the ordinary happens, even adding toner. Some genius has to mess with every little thing before changing the toner, or removing the jam.
wild_guest: same as above.
pepito17
04-17-2009, 09:42 AM
Hi guys ,in my error is 74100025453, what can?
LNorris
04-21-2009, 09:39 PM
on a printer error code, the first 4 numbers are the actual error. the numbers after that is the page count for the machine. so the same error is for all 3 mentioned machines.
