View Full Version : Miscellaneous B215 Driver Defaults to Letter all the time
nyathim
02-20-2013, 05:57 PM
Hello, please assist i got a number of B215 running on a PCL5 driver and no matter what i do by defaulting the driver to A4 paper size and applying settings it goes back to letter which then causes the printer to throw an error. and users are getting very upset with that.. all programs have been defaulted to A4 as such is our paper size which is A4. the Xps driver causes more problems and headaches... i will be glad if i could do away with this..
NOTE.. the B215 has had the default paper size set to A4 as well.
EarthKmTech
02-20-2013, 10:27 PM
if you enable auto continue, this should stop the warnings and convert to A4 usage at the machine. However you may end up with margin issues and page splitting of certain documents.
When you get any printer installations that default to letter instead of A4, its usually because the dumbass who initially setup the computers never setup the regional settings correctly. As per usual, it must be our fault though..
